Was read on many forums, alots were not impressed with Fury X performance neck to neck with Titan X, Fury expected to be 10% slower than Fury X so it put Fury at GTX 980 OC level but lots of owners overclocked it to 1.4 and 1.5GHz core. AMD will have huge challenge to sell Fury and Fury X cards with same performance as 980 Ti and Titan X, many people will be glad to keep GTX 980 with monster 1.5GHz core that is faster than Fury and others will sell it cheap second hand when they upgrade it to 980 Ti. Both GTX 980 and 980 Ti are very attractive products and prices now.
So far these are not official...
If the fury pro is indeed 10% slower, then yes oc 980s are close, until you OC that 10% back on fiji or even more (which is easy even on the not ic friendly hawai chips), and the OC 980 disappear in the dust again.
You need to seriously cut the fiji to fall back almost 30% to 980 level.
Basicly fury is matching the TX and Ti...the difference is when the latter to appeared every panties were full wet how awsome those cards are, when amd brings the same performance its meh....
