MSI specs leak: http://imgur.com/a/NvH4z
Apart from the slight bump in core and memory clock this just looks like a 290X to me![]()
Decent specs on that MSI 390x 1100 on the core and 6100 on the mem, 8gb VRAM should be fairly decent
True that.
So, is the 16th still the date for the Fury X or do we still not know?
That's what the 390X is.
390 has same specs as the 390x but with a lower core.
By specification yes, Tonga has the same number of Shaders as Tahiti, also rumored to have the same 384Bit Bus, what they are not is the same GPU.
Yeah 208W is a odd number, AMD pretty much never have a TDP that isn't either rounded to xx0 or xx5 so I can shenanigans as well.
Sorry what, this doesn't make sense as an actual technical sentence.
You're saying codenames like you're talking about a specific card.
I'm guessing that you basically think the 390X will be an 8GB Tonga 28XX shader GPU?
Also, what's with all the HBM hype if AMD aren't actually properly moving to it yet.
HBM is for the new top end cards.
If the Fury is not shipping in the ark of the covenant instead of a cardboard box, I will not be purchasing.
