Oh wow, that's some major temp difference for my two cards in SLI. Adding another card might boost that even more for idles. Both still on reference coolers.
I have no flicker or issues with my ROG Swift. It's been a treat, it might be a dodgy cable, if not it's the monitor probably.for the few that have been fortunate enough to have received there
Gtx 980 TI'S how are you finding them? Love'em
are the drivers serving you well? No issues at all in everything I used them on
any particular tweaks to get it going how you like? Simply turning on SLI, and G-Sync
what are your overclocking results? Not bothered, the Superclocked cards do well enough
are you on stock cooler or water? Stock reference cooler
what are the temps like? Idles are good, temps peak at 84 for 1290Mhz, quiet and no throttling
I find display port has a flicker now and then,
I take it the drivers need to be optimized as a lot of titan x owners currently face the same issue,
anyone have any input on this flickering problem I am using a Asus monitor with a GSYNC module installed when they were first released?
