Well it revs fine stationary. I did notice that it's only at 75-100% throttle that it bogs down in any gear.
I had something similar with my WR450F and it was the stator(?)... Not enough electric power to spark properly, or something like that?
Still rainingso I got some bits installed on the bike
Evotech Tail Tidy with Ducati Performance LED indicators, really happy with how these look together and the LEDs are nice and bright, stock bulb type can hardly be seen flashing so safety upgrade also!
Just need to drill some new holes in the plate until the V5 comes through and I can get a new one made up.
Also waiting on my seat cowl, no passenger pegs installed but a pillion seat looks a bit weird.
I didn't want to shell out for rear sets so just replaced the stock slippery cast aluminium pegs with the DP machined ones, so much better just riding it up the drive into the garage, the stock ones angle up at the ends like a little ramp for your foot to slide up off and these ones just grip.
ProGrip 717s, used them before and found them great for my larger hands, feel so much nicer than the stock ones and also come standard on the 1199 Superleggera so must be good![]()
Just need to get out and ride it more now, fingers crossed for some dry weather!
899 Pani? Welcome to the club if so. Had mine since new last year and love it!
Thanks, it sure is
Have you done much to yours, any pictures?
You will find when you start throwing bike about that the stock seat is slippery
@scort it might need new plug leads,usually its something simple,stators are expensive as well
@clim that's a common trait on Italian bikes,soon as you turn engine off it will click into neutral fine,my cagiva did it,was told by a mechanic its just the nature of the bike
That's a good thing for shifting your weight about.
but no good for your plums on the tank!![]()
Yeah I already have the race seat, at 6'3 I needed the extra bit of height and the race seat is more comfortable than stock anyway in my opinion.
And tomorrow I'm road testing this..
