Permabanned
- 4 Sep 2011
- Durham
Well there's the 20MHz clock speed difference haha.
Whut! That 0.0001fps is a total deal breaker for me...throws titan in bin
Might be selling my 2nd Titan X to get funds for the Fury X![]()
You selling 1 and keeping 1?
Yeppers
I'll be replacing the Sapphire Vapor X 290X 4GB in my AMD rig, Yes I have an Intel/Nvidia rig and an all AMD rig
At the moment it comprises of an 8350 at 4.50GHZ, 16GB of 2400 Avexir Blitz 1.1, Sabertooth 990FX all in a Corsair 540![]()
Ah I'm with you now.
So you're going to have one Intel with a single Titan X PC, and one AMD FX with a single Fury X PC.
Best of both worlds.
Well going off the "Leaked" benchmarks, the TX and FX are neck and neck.
...and a TX x2...If the results are close it would not be surprising if Nvidia dusted off the Ultra moniker and launched a '980ti Ultra 6GB' with the Maxwell chip from the TX. There is always room for a Titan X Black too![]()
...and a TX x2...
My card is running pretty hot and loud on Witcher 3. 87C and 3100rpm, not far off my old reference 290x for noise.
Maybe time to look at getting a new cooler.
Does the ACX 2 come with the thermal grease needed?
Strange, I'm running SLI and running under 80c. Is your case cooling any good and whats that in % (3100rpm) ?
Yeah I have a FT05 so cooling should be no problem. That's 65% I think.
