Cap the frame rate or try using individual 8 pin connector cables if you are using 2 way splitters.
Failing that keep buying PSU's till one gets you a better result, or keep buying Fury X cards till one gets you a better result.
lol.
Do you play games on a HDMI 2.0 4K 60hz TV or intend to do so in the not too distant future. No then you don't need it.
I was wondering if there is even a 4K TV which is at least 40 inch in size with 60hz and which supports HDMI 2?
yep 4K60hz TV ... And I like my experience with this type of setup, I know you get a bit more input lag with TVs, not as good response time, but I don't play FPS. I was going to go with 2 fury x's ... I was so excited about purchasing them, that it didn't even occur to me that they may not have HDMI 2 ... almost cried when I read it for the first time lol.
This maybe explains why gentle typhoons were so hard to find. AMD bought all the stock.![]()
Yes my samsung 48 has 3 x hdmi 2.0 60hz 4k 4:4:4 colour. It suprises me that no one looks beyond small monitors
I often ask myself the same question also, but then you don't get the same response times on TVs and often a lot more input lag, so I can also understand people wanting monitors. 40+ inch monitors woold be cool especially with 4k
Modern TV's have pretty good response times.
Its a huge fail for AMD given the very appealing form factor of the card.
This arrived from Lovefilm today. I think it's a sign.
FURY
AMDMatt needs to report this! He somehow managed to get his hands on the Fury that's not even released by AMD yet!
Need to alter a lot of the physical properties on the card for HDMI 2.0 and they kinda are going the displayport route.
