I'd argue - Learn how to properly front-brake in a bend!
You can do it and some schools teach it, but it must be used with care, else you risk overloading the front tyre and spinning the back out into a lowside.
Having binned a 125 doing just this, I find it works easier on heavier bikes.
Isn't this called trail braking.. a bit like dragging your rear brake through the corner for fine adjustment on the exit. Except with the front you want to be breaking before turn so the tyre is mashed into the ground before the corner so as you turn there isn't any sudden jerk of movement through the forks or on the discs. Brilliant for if your on a 'spirited' run and aren't to sure of the roads
EDIT: Well maybe not 'mashed' that sounds extreme, what you want is to be gentle and plant the tyre. Anyway works great for me.
