The GTX 980 Ti owners thread.
Never used event viewer but its reporting as a event "41" kernel power.
"The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly."
Just FYI, the only thing I did bump up was the voltage to +87 on Firestrike Ultra.
Dang, you read my mind, I just tried it this second and came back to report that its working fine, thanks.
So does this mean I cant run with aggressive settings (as I was doing on Firestrike standard and extreme)?
Or it went far beyond the power limit?
On full load my 980ti seems to make a funny noise, the best way I can describe is when a cable slightly touches a spinning fan (I've checked and there's no cables in the way). Is this a normal noise?
Try whacking the fan manually up to 100% and see if you get the same sound.
If not, it then sounds like coil whine etc.
Tbh its not an issue I reckon.
At 100% speed I can't hear anything but the fans :) The noise only really becomes apparent at about 45 - 50%
It's something I can live with as I previously had a Corsair H80i installed and on full load that thing made a racket. the 980ti is nowhere near that level of noise.
My EVGA card has a really annoying resonating sound at certain fanspeeds :(
I heard about this on the 780 series but I thought they had fixed it.
If you have the EVGA ACX 2.0 fan solution. Take a look at this thread:
EVGA GTX 980 Ti ACX2.0 Annoying Fan Noise at 35-37% RMP
Might be of some help. Do not have any ACX 2.0 myself yet. Probably going for the EVGA 980 Ti Classified (when available). But researched a little, and stored that link for later.
