https://sfx.thelazy.net/games/preset/3511/ here you go
EDIT: Just had a quick go with it on i keep getting around 10FPS dips every so often might try with vsync off and then try with adaptive see if i can stop it.
Is anyone getting to know the city at all? I haven't played this anywhere near as much as San Andreas yet but in that game I knew every single street. This is a much bigger map and some areas are quite complex - has anyone got to know the place intimately, or do you follow your GPS and map?
I wasn't even sure that omega was still a thing, I thought it was just temporary. I would suggest at least using the catalyst beta drivers as these have been optimised for gta 5. Edit: Yea, those drivers are over 6 months old, I would get rid of them sharpish.Since last patch I've been getting bsods, not had time enough to play it regularly due to work, the bsod says something about a dpc routine error x00b8, crash dump says its probably ntkrnlmp.exe but google says thats usually a driver fault, it ran flawlessly before this patch, anyone got any ideas/possible fixes? I'm on catalyst omega 14.12 which seems to be the latest, & was using them before this patch.
Can post a crash dump if needed, but guess that would be better in a different section of the forum.
Thanks.
Traitor! allegedly reinstalling directx may fix it. But maybe you'll be stuck with it like stark and his 970.Been playing GTA on my AMD card since release and never had a single crash but after upgrading to a 980 yesterday I just got my first CDC with a 'ERR_GFX_D3D_INIT' error message![]()
Yep, I know my way around a lot of places but there are a lot of places where even with GPS it can be hard to know which way you're going at the spaghetti junctions.Is anyone getting to know the city at all? I haven't played this anywhere near as much as San Andreas yet but in that game I knew every single street. This is a much bigger map and some areas are quite complex - has anyone got to know the place intimately, or do you follow your GPS and map?
My garage is complete tbh:
All maxxed out pretty much and all in Midnight Purple.....I have a fetish![]()
A Sultan AND an Elegy? Marry me![]()
Can't decide if you're mocking me
I love the Elegy!
I love the Elegy!
When I played this at release in sli, it ran very well, now it runs much worse. I'm hearing the latest patches broke it for many 900 series users.
Have to say my experience with GTA V has been very sad today.
Hope they fix it in the future so I can enjoy it as what I saw of it so far looks really good - if only the tech issues were resolved.
EDIT: fixed a couple of my issues now. To play GTA V offline and get around the temperamental social club launcher I just added -scOfflineOnly as a shortcut command line. I also appear to have reduced the stuttering by forcing vsync via nv control panel and disabling in game.
Anyone know how i can turn up my brightness a little, i like it dark, but its a little too dark when i use Lumasharpen, but it looks much nicer using it so i dont wannna disable it.
i get stuttering when playing logged into R* social club.
when i play in offline mode its gone.
