Congratulations Gregster![]()
Cheers and people won't understand how happy I am. Gaming with all that tearing was horrendous
Now time to get down and dirty with some 1440P testing
You are missing the point though. They are not the exact same scene being run on each card, they are as near as he could possibly get using the same scene in whatever game it was, which can change how things look greatly. You can see in the still that the character is not in the same place so it's therefore not the same image and you can't make any comparison only a preference (like with everything) to which you prefer. Hope that makes sense.![]()
Well debate that vid as much as you like, but having watched it with less tired eyes, they both looked good to me.
On a very very enjoyable note, I now have 120Hz at 1440P working wooot![]()
Here is an example of what I'm referring to...
Same on the gun, you have less gray detail on the scope etc.
It does not matter if where he is looking is identical. Things like the lines in the road should look the same into the distance. Yet they are fading in at a short distance on the TX. But are well defined into the distance on the FX.
The blurring has nothing to do with The recording since the line looks faded on the TX where as it is solid and sharp on the FX. If it was just an artifact of the recording there would be a blurred but solid white line into the distance. Yet it looks transparent and blurred on the TX which is a rendering issue as the surface underneath is visible.
as in this picture with the line that follows the curb.
Greg said from the start that he altered the colour settings on the Fury x video.
So you're saying it's brighter on Fury X so it must be better image quality where as i am saying you can't use brightness of colour to determine image quality. You could adjust settings and get the Titan X to look brighter than the Fury X but that then wouldn't mean the Titan X suddenly has the better image quality. By the way i have an AMD card and prefer them as a company but honestly i prefer the look of the Titan X.
I am not talking about brightness of the image. I am talking about the definition of the white line that follows the curb. It is solid and well defined on the FX. Yet it blurs near the player and you can see textures underneath the line on the TX.
If it was the recording then the lines would both be solid and the tX line would just look like a solid blurred line. But on the TX it is faded near the player and you can see textures underneath the line. Which is a rendering issue.
The blurring has nothing to do with The recording since the line looks faded on the TX where as it is solid and sharp on the FX. If it was just an artifact of the recording there would be a blurred but solid white line into the distance. Yet it looks transparent and blurred on the TX which is a rendering issue as the surface and other textures are visible underneath the line.
http://kepfeltoltes.hu/150702/Desktop_2015_07_02_09_35_04_173_www.kepfeltoltes.hu_.jpg
I'm sorry but from what i see the one on the right being the Tx looks much more defined than the Fx and is also less blurry but it still doesn't determine image quality because they are not the same image. You need high res stills or videos showing the exact same scene with both cards at default settings.
There are just too many variables in the video provided.
I've started using Raptr, Greg. I quite like it so far, though for the life of me I can't seem to get the fps number displayed. No idea why. :/
you can set that in raptr; mines set pageup+f key......it won't show in the videos but shows on screen
The video is perfectly fine to pull up rendering issues as both halves were recorded at the same quality and with the same capture device.
Here is what i am talking about which you keep ignoring or just don not see.
It is a texture filtering issue on the TX. Either there is an issue with BF4 and nvidia drivers or Nvidia are purposely fiddling LOD to boost performance.
