The GTX 980 Ti owners thread.
Yes, haven't touched a thing!
I dunno? It says 7010mhz on the site so i don't know how that translates.
Have a look at GPUZ and see what it says for the memory speed. Yours is reading about 200mhz lower than it should be according to that screen. It should be 3505, which doubles to the advertised 7010.
This h440 isn't great for cooling, I don't overclock for gaming, only when running benchmarks :)
I'm going to keep going, running fire strike now to make sure it's still stable. Which it seems so far
So to confirm, this would be my boost clock? 1392.
If that is heaven or valley, then it is most likely not correct. They are known to provide incorrect clockspeeds. Use gpu-z or run the rivatuner osd to give more accurate information.
I exchanged the Gigabyte 980 Ti G1 due to coil whine. Got the MSI 980 Ti Gaming 6G and I'm quite pleased with another great Twin Frozr perfomance. Its very very quiet compared to the G1, and has absolutely no coil whine. Perhaps I was just unlucky, but my G1 singed songs like a whining bird.
I have a second 980 Ti Gaming 6G twin frozr incoming to run them in SLI. Hopefully I'l be fine going double non-reference assuming my case is well ventilated.
FINALLY got my AMP! in.
Stock boosting to 1253mhz on the core, will give it a little OC but already its proving superior to my 780 SLI.
What took you so long.:D
Nice to hear, also finding the msi ge to be a nice improvement over 780 sli. Great to be able to game in blissful silence and my case isnt like an oven.
Haha, work got in the way, until tonight :D
Just had a little OC, 1490mhz boost and the only thing holding it back any further is the power limit :D:D
Card is REALLY quiet too. Very happy with it.
Know the feeling mate.:)
Stock boost of 1328 here, +150 nets 1478 boost, 75% fan speed and still cant hear it, havent touched the memory or voltage yet. The above scores around 200 points better in fs than the 780 setup.
