GPU stock/hbm stock: firestrike GPU score: 15981
GPU stock/hbm 585mhz: firestrike score: 17166.
Does it run at 650mhz?
Not quite anyone. I think someone was suggesting the TX screenshot was exhibiting superior AF.
Can we get the discussion about how nvidia is cheating to its own thread please? Anyone?
It's relevant because if Fury X has AF enabled and TX/Ti don't then it would explain the massive discrepancy in performance.
Been asking for screenshot, but credit to Greg he doesn't want to be involved in this..
Lets look at another user, claiming his old screenshots on a 780 shows the same thing. So DP would you like to be the first user to head to that point and take a screenshot?
Regarding the white lines next to the kerb, looking back through some old screenshots from last year when I was running a 780. They look very much the same as the image above for the tx.
http://forums.overclockers.co.uk/showpost.php?p=28261618&postcount=35
Does it run at 650mhz?![]()
It's obviously some kind of AF issue which Gregster overlooked, I'm more interested in why the Fury seems to be exhibiting black crush.. does it occur in normal usage or is it a capture issue?
Just look at the gun, grey and detailed on Titan, a black mess on Fury.
http://www.3dmark.com/3dm/7597042
This 4690K seems to hit a voltage wall at 4.9, but still not a bad chip or score for a well priced CPU. Card doesn't do too well without voltage control but no less than expected. 1110 on the core.![]()
Greg did say he messed with the colour on the FX.. Maybe he over done the brightness level? maybe the FX is set on RGB full but the capture device is running RGB limited..
You correct though his black level is abit off in that shot needs tweaking a touch. But in also saying that the TX black level is way to high also.. Shadows are just lacking detail and shouldn't be that gray. In fact the FX level is more closer to being correct than the TX.
http://www.3dmark.com/3dm/7597009
my physics score is nearly double, yet the overall score is just a bit higher. Granted I ran it with stock core clocks![]()
No offence but honestly who gives a ****.
Yeah don't get too excited you should see my other CPU![]()
Touchy! Wasn't replying to you so............ YEAH!
I am not. I don't game fire strikes, so it was just interesting to see how not important the cpu is in that benchmarkAlso my 5930k is clocked very mildly compared to other more experienced and gifted overclockers around
You can see my point though? There could be all manner of reasons it may even be something to do with NVAPI, but the point is - it's really not big a deal. You're not going to notice it when you're gunning people down.
It's pretty important! 1080p FS is very Physics score biased compared to the higher tier tests. Give the i5 some love
If you're so adamant it's something to do with the capture card you're asking all the wrong questions?
You make my brain ache lol.
I did ask that this thread be left for the owners and to discuss Nvidia AF and other bits in a different thread. I am also interested in what people think, as I literally just installed the drivers on the FX and adjusted the colours to my liking but never touched those on Nvidia when switching over.
I will start a new thread and people can discuss it as much as they like. I also agree that something looks up with the kerb line distance and it isn't something I did, so must be at driver level or something else that I don't have a scooby on.
Anyways, Review is now being done for those interestedSome might be surprised
