I'm sure a custom fan profile will drop those a fair bit. Shouldn't see much if any rise in noise either.
I came from an amd card no issues in fact my os was installed in 2012
Modern os handle upgrades fine.
used to be the same os install when I was running an amd chipset evenrebuilt the whole pc apart from the ssd and hdd which stayed the same.
never had an issue with windows, pc on usually 24/7 no blue screens or memory dump reboots
Seems like a quieter G1. Another nice card, which should cost no more than the G1 though.This is the first proper review of Asus Strix card I've managed to find - it's from a polish website, so I've chucked it into google translate.
https://translate.google.com/transl...ix_gtx_980_ti_directcu_iii&edit-text=&act=url
Why thank you
Reading to many things about it going wrong, and i can't figure out how to do it. I'm just going to leave it!
Setter, what oc did you settle on? I've gone +100. I've not tried inbetween but +150 would crash pcars.
I'm now boosting 1430/40 with no problems. Shame I'd like to hit 1500 in game like I can when I bench.
How!? I follow that thing, not a clue how to select the folder through cmd, type the directory nothing comes up.
Open nvflash, with the bios in the same folder, can't figure out how to open it, push one button and it does something and closes
What am i doing wrong?
Although, it is boosting to 1480ish at the moment but hitting the power limit on the very odd occasion.
For daily use I just run stock tbh. Tried 170/200 on firestrike, whilst it completes the tests my score actually dropped. Must've been throttling either due to power limit ir temp. Need to test some more. 170 boosted to 1499mhz.
Have gone back to stock bios on mine. Still manage to get 1500 core. Only difference is it sometimes drops,down to 1475 I think due to hitting power limit.
Scores a bit lower in benches, but I doubt I will see much, if any, difference in games.
Right click on the nvidia flash folder while holding shift, click open with command, and then type what it says from the guide
Make sure to disable your graphics card in device manager before you flash your bios![]()
The person I was posting towards does have an issue and I have seen this same error before hence why I posted. May be he has already done a fresh OS install.
Either way a fresh install is never a bad thing to do and always ensures your getting the best performance out of your £550 + purchase. Personally I would never do as you have done and leave a refresh of an OS so long or change chipsets on my main rig without a refresh. A fresh OS install doesn't take long these days and a pc is never worst off for doing so, so why avoid it?
Yeah I saw my score drop..at 160.. So backed off to 150.
Out if interest what is you basic?
I can't do it, it says not found this and that. I give up!
I'll do you a quick video tomorrow showing you how if you haven't managed it
Stock boost is 1328mhz.
