- 2 Apr 2011
target temp by default for msi seems to be 83c according to afterburner (might actually be lower in the bios and 80c(
if your card gets hotter than that it will stop boosting and may even throttle to below the guaranteed boost.
I suspect your old cooler was poorly fitted
it sounds similar to a windforce 280x I rma'ed for the msi version.
windforce was 100% fan under load and silly temps like high 80s on stock clocks and vaults
put me right off gigabyte since it was noisy as hell and was meant to be one of the quieter 280s
The fan actually stopped working after a week so I had to get it RMA'd. I'm glad it did because if not, I'd probably have stuck with it thinking it's normal and just my case having poor ventilation.
