- 18 Mar 2012
- Eastbourne
How do you check the so called "ASIC quality percentage?"
http://forums.overclockers.co.uk/showpost.php?p=28280196&postcount=4072
If you go from a AMD card to a Nvidia is it best to also reinstall MSI AB? Or pointless.
Thanks for the heads up, much appreciated.It is indeed!
I don't hit my power limit unless i'm past +65mv in AB.
Whack up the voltage and find out
From what I found is that, upping my voltage just makes me get closer to my power limit and the only way to stop that is to flash bios, which I can't work out![]()
It will just be our different fan profiles - takes a fair bit more whack to drop 5c & I tend to go more aggressive.
What's your overclock your running at?.
Follow my video and you'll manage it![]()
Cheers. I get 74.7%. That any good?
I have, it pops up saying no nvidia adapter found![]()
I think you should sell the 980Ti and move to AMD
Noob!I think you should sell the 980Ti and move to AMD
Do you want me to do remote assistance for you and set it up?
my cherry picked binned and tested 980 is 66.5% so yeah you're doing great.![]()
Thanks for the pointer, it seems I can get the same score if I drop the volts & core by a little as it stays at the limit (as opposed to it constantly bouncing it).It is indeed!
I've come from AMD, I don't want to go back!
If you wish![]()
