- 7 Jul 2009
- Newcastle/Aberdeen
How do I calculate that? I'm about 160lb myself.
http://www.dorkypantsr.us/bike-tire-pressure-calculator.html
I keep both at 110psi and then pump back up as it gets spoongy/soft over weeks.
Isn't that way too high? You could be enjoying a smoother ride over London's potholes!![]()
If I go for 190lb (165 for me and my clothes, 25 for the bike which is definitely an overestimate) and opt for 45%/55% weight distribution it says I should go for 73psi up front and 92psi at the rear. That front seems awfully low. The tyres say the minimum pressure is 73psi. I wonder what that would feel like, or whether I'd be at risk of pinch flats...
I imagine 100 or 105 is right for Grudas' rear![]()
it might be on the high side and for a week or so after pumping it up it feels quite "harsh" but after that it's all good! to be honest, with the number of potholes, manhole covers with sharp edges etc, high psi is pretty much a must not to bottom out your tire and hit the rim? what pressure do you ride around on?
I don't intentionally ride over stuff for starters.
I run 80/85 F/R but according to that calculator I can run 50/80!![]()
Have you got it in 45/55 weight distribution mode?
I imagine 100 or 105 is right for Grudas' rear given all the beefcake![]()
but you know, lundun is not all perfect driver wise so once in a while you've got no option just to bang that pothole.
45/55 weight distribution would give 58/73
I find the ride quite smooth already with 80/85 on 25mm tyres. I wonder if I'd gain much by riding them at, what seems to me to be, really low pressures.
lol, I'm not heavy, hoovering around 12.5st lately!
Ah, fair enough. I assumed more like 90-100 KG with beefcakery![]()
I struggle up hills already lol
