Just pulled the faceplate off the mater socket, connected to the test socket. 38 megs... happy with that
Just for info, i have no crc errors - the modem is working well
Give it 24-72hrs.
Do you have extension sockets wired to that faceplate you pulled off?
yes, two extension sockets. is that an issue? I dont use them
Yes ...Does the detailed stats via telnet still work? I forgot how to look at it.
YesWas it just enable telnet then use putty then that input text?
