Good morning,
Can anyone tell me if it is OK to install the latest drivers from the nvidia website on my X5 or would this cause a problem?
When I use the nvidia geforce experience to check for latest drivers it says I am up to date with 348.10, but nvidia website has 353.30 as the latest drivers available.
Cheers,
John.
So ultimately the choice is yours, but we believe the safest way is to follow the updates that you will see in your Driver Update app, as these will have been tested by HQ for your machine.
Hope that helps,
Regards,
Gigabyte UK NB Team
Cheers Atom80.
May as well give it a whirl as GTA5 has crashed the driver a few times. Frame rates don't drop, but the program has crashed. Windows 8.1 says the driver has recovered from a crash. I then have to terminate the program and restart it. Last time it happened I was playing windowed at 1920x1080 and could see the error message.
I will download the driver from your site and have that as a backup if all goes wrong.![]()
Grabbed myself the X7 v2 bundle promo.
My mind was initially set on the X7 Pro (which admittedly was stretching my budget) but the v2 strikes a good compromise between price and performance in terms of work/games that I intend to use it for.
The added M7 thunder mouse and B7 backpack only sweeten the deal![]()
Hello again metamorphoses!
Great machine, great price, sweet bundle,,,, hope you enjoy.
Regards,
Gigabyte UK N Team
The X3 has been perfect in the lab so its bigger brother should be a great replacement for my 6 year old laptop at home.
Hi zegger,
At least you are sorted now by the sounds of it. We will sort the hoddie and USB with OcUK next week, you will get them, don't worry sir
Hope you enjoy the notebook when it arrives.
Regards,
Gigabyte UK NB Team
Hi Atom,
Just wanted to say that I am absolutely thrilled with my new X7! It is a beast and it looks fantastic!
A few quick questions/small issues though:
1. Is there anyway of using using one of the HDMI ports as an input (for hooking up a console to the monitor for example)
2. GeForce Experience won't optimise my games as it says that the processor does not meet the requirements. I am not really sure why this is happening as it has a 5th gen i75850
3. The Command & Control centre does not open when clicked. The only way to make it work is by reinstalling the driver, it will open once but when you close it it won't open again (even after a reset)
Finally any update on when I will be recieving my hoodie (Medium UK size) and memory stick? Looking forward to having completing the look when I am carrying my b7 rucsake haha!
Many thanks,
John
Hi zegger,
We will endeavour to get answers on your 3 questions asap, but these may not come through until Monday due to time difference with HQ.
Hoodie and USB - despatched today
These are being despatched to what looks like a business / work address, is this correct? (the invoice address for your order)
Regards,
Gigabyte UK NB Team
I echo this for my X7 as well, if anybody could recommend a good laptop cooler? Thank you.
There are very few actual coolers that will fully support the dimensions of the X7, a lot of the coolers state that they support 17 inch laptops, but this turns out to be only for units with approximate dimensions of 380 x 290mm. The X7, is some what larger than the average unit at 428 x 305mm.
Well I took the plunge and went for the Cooler Master U3 (designed for 19" laptops) as this was one of the very few I have been able to find which actually supported the full size of the X7.
So far after a couple of hours of playing Dying Light, I can honestly say that with some tweaking of the fan locations. The chassis of the unit is considerably cooler after using and according to HW Monitor, the CPU & the GPU temps were lowered by around 5-7 degrees.
So far this is cooler is doing a nice job and the lower temperatures are nice. I would like to know what other coolers X7 owners are using and their views?
Hi Atom,
Many thanks,
John
Hi Atom,
Many thanks,
John
Hi John
Thanks for the screenshot, this was sent to HQ, and also passed over to NVidia. We replicated the same issue yesterday, but today we cannot, so it seems there was a bug somewhere, and hopefully you will now see the same as us,,, ie its fixed.
Please let us know, and thanks for the feedback as this has identified, and now removed something we and NVidia were not aware of
Good work..
Regards,
Gigabyte UK NB Team
Hi Atom,
Yes it seems to be working now! Great!
I still can not launch the Command and Control app despite updating the driver. Even the fan presets on the macro keys will not work now... any ideas when this will be fixed or if there is anything I can do on my end?
I have also noticed that Skype for desktop will not recognise the inbuilt webcam. Any ideas on this or perhaps it is a skype issue?
Overall I am still loving the laptop, and these are just small issues... it is just for the £2600 price tag I want everything to work perfectly![]()
Thanks for your support so far! It is has been very attentive!
Cheers,
Z
Hi Atom,
Cheers,
Z
