Is anyone running the msi gaming in sli? Just wondering what the temps are like compared to reference cards in sli.
Worse, the top card was 83-84c. Reference 78c.
Hmm, I wouldn't mind going back to reference cards if I knew I could get similar overclocks to my Amp extremes. They both run stable at over 1500 but i just can't kep them in sli due to the top card being almost twice as hot as the bottom one.
So I'm thinking of getting an 980ti, would it be best for me to get the Gigabyte GTX980Ti G1 Gaming version for best overall performance?
They sure are hot *******s!!! The top one certainly doesn't like the furnace beneath it![]()
What monitor do you have Beasty? Reason that I ask is that using Adaptive Vsync on mine (limiting it to 60fps) keeps the temp/noise down quite well and more than bearable![]()
(I also had to re-arrange my case fans slightly but now I have one pushing air in-between my cards so is helping a little too)
I'm running an Asus PB287Q so i'm limited to 60fps anyway but at 4k. I did try them out for a bit but with the tiny 5mm gap between both, my bottom card was at 48c and my top at 82c with fans at 80%
I knew I shouldnt have gone ahead but on overclockers advice I chose to do it. I hate to request a return on these cards but on this occasion I do feel it's not my fault so I think I'm gonna have to do it. I'm looking at the msi gaming versions but I'm still worried about temps.
I gotta be honest mate, those temps wouldn't concern me. When unleashed my top G1 can hit 91c!!!! Adaptive Vsync has really sorted me out and only hits 80 now which is more than acceptable
Try it, see if it improves things? Not like your monitor can take more than 60fps anyhow!!
As an aside, just checked out the Hexus review of the Zotac and it's a MONSTER!! In some games it's 30-40% faster than the FuryX and that's at 4k!!! Holy ****!!
http://hexus.net/tech/reviews/graphics/84722-zotac-geforce-gtx-980-ti-amp-extreme/
Considering they're produced on an old node, these really are great great cards![]()
Get the front intakes sorted and try adaptive sync, I think combined they'll help out a lot
OK will do, on another note, is watercooling an option for these cards ?
Don't like being in the dark about VRM temps and help spot potential issues with cooling on either cards in my case.
I NEED TO DO THIS. The green is ruining my look. I'm too scared to take my card apart though![]()
They're custom, so fairly unlikely. I know someone is producing blocks for the G1 but unsure on the Zotac. If that's the route you're thinking of taking then maybe send them back and go for reference? Or send 1 back and live with the 1 card for a while?
Before I got my second G1 i *did* plan on getting a reference card and fitting it with a Hybrid cooler (or just getting a Hybrid card). They'll SLi together fine, and might be an option for you? And then the top Hybrid card will take the heat a lot better...
EK are currently doing waterblocks for the MSI Gaming 6G, Asus Strix and Gigabyte G1 in the next 1-2 months. Not sure on any other cards at the minute. I think its a similar story with other blocks aswell. They tend to do the cards that or more popular or/ receive first.OK will do, on another note, is watercooling an option for these cards ?
I'd be more than happy to buy 2 hybrids right now, there's no stock anywhere so it's not possible
