- 1 Apr 2010
With a bit of playing, moving to custom bios doesn't seem to help much with my cards.
It's enough to get me to 1500/8000, whereas just regular bios gets me about 1475/7900. Extra voltage doesn't seem to help me very much at all.
Was wanting constant 1500/8000, but the performance difference is negligible, so will just stick to regular bios and 1475.
Regular bios with voltage increase also seems to allow 1500, but is not stable in batman.
Also 1475/7900 seems about the limit for tdp. Adding even +25mv starts throttling a bit in certain situations.
I got similar results on mine. The custom bios stopped me hitting the power limit which allowed me to up the clocks but not by much. I'm using 1.27mv at the moment and the extra voltage doesn't seem to do anything, I can do 1450Mhz on stock volts ie 1.187mv. I am planning to use the 1.25mv bios instead to scale back the voltage and just remove the power limits as this is all I need.
This extra voltage situation pretty much ties in on what I have read on a few forums and stuff kingpin has posted about the 980ti chip.
On the plus side its a 50% boost over the base clock is very nice. Nvidia really could have released these cards with allot higher clocks.
I'll see if someone has one second hand.
