[Damien];28339759 said:Sure, sounds good. 7:30ish?
Yep, I'll pop down to yours.
In other news, slightly closer future me is thinking that he'll buy a power meter of some kind next year and buy a 5800 groupset to replace the Tiagra on recent past me's Planet X bike.
Cheers Gents
I had a little spin on the turbo last night just to make sure all was well and while sweat was pouring off me I was thinking that using my phone isn't really ideal so I'll take the laptop with me to use.
I'm thinking ANT+ might be the way to go. At some point I'm going to update my Garmin and my wife has a Vivofit so I've got an ANT+ USB stick I can use already
I'll pick up a heart rate monitor at some point but I'll start off with speed and cadence.
Not too fussed with videos at this point. I'd rather do 20 or 30 minute focussed sessions than anything longer so some music should be enough to keep the boredom in check.
I was surprised at the maximum resistance (or lack of) that the Cycleops offers when at max setting TBH. I was kind of expecting it to be like riding up a 20% gradient on a road made of treacle but I was able to keep decent pace in top gear for short periods. I may also disconnect the remote resistance control as you don't use it on TR.
Repeated my longest ride of the year today (a modest 36 miles) and it felt pretty good. Off to the middle east for another 2 weeks on Friday so no cycling again
I think the power meter was separate to the 5800 upgrade for the PX bike.
Info?
Roady said:I've tried basic DHB (2 Active, 3 Flashlight), 1 pair Castelli, 1 pair Altura and 4 Northwave I'm heading back towards some more DHB. Probably the Aeron or Pro ASV. The Actives I have are rubbish on any rides over 30 mins, fine for short easy riding/commuting. The Flashlight are better but after a couple of hours they're uncomfortable, almost on par with the Northwave as any rides over 3 hours in them I get some pain/discomfort (sit bones). The Castelli and Altura I tried were on par with the Flashlights (not as comfortable as the Northwave) and I found them poor fitting.
Santini and Endura will be brands I check out soon as lots of scope within their ranges. Although part of me thinks if I'm spending £150 on a pair of shorts (unlikely) I should get some Ralpha's?
So.
I've bought my first tub of chamois cream.
I won't disgust you with the details but it was a necessary purchase after a recent ride.
TTIUWP.
Did you get Roady to show you how to apply it?![]()
I get a bit raw just behind the balls
WTFBBQ?
Pfffft! We have a new expert on describing chamois creme application:
TTIUWP.
He turned me down.
He turned me down. Any chance you could pop round later French?
