So 1215 with voltage tweaks.... Just as I thought and poor![]()
The video with the shaky camera is showing furmark running @ 1242mhz. These guys might not be pushing the limits either.
I've done exactly the same, was a little hard to get used to at first , but moved mine back & anything less than 40" looks tiny nowThe 40in is lush tbh, although I did go through a small period of thinking it was just TOO big!! Pushed it back another 6in and now it's perfick![]()
The 2 i had did it oddly enough![]()
Wow 4K 60hz displayport to HDMI adapter, if that is the case, then that is exactly what the doctor ordered for the non HDMI 2.0 fury problem.
Link to them if you can or just name them so we can search.
Sounds like a hack to me. I will wait for an official Afterburner..
1215 is wayyyyyyy too low with unlocked voltage. You can hit 1300 on hawaii with water without too much trouble, I find it hard to believe fiji can't even accomplish 1215 which is possible on air with hawaii.
Are MSI actually releasing support for it, I haven't seen any statement. Maybe they are holding off for long term testing given the radically different design of the Fury series?
Msi afterburner is developed by a third party who didnt get a board to play with, hence no update
It s a 21:9 right, so the 40" diagonal is not the same screen size as a 40"16:9.
looks to be a perfect size for me.
BDM4065UC is 40" at 16:9.
So my 2 sapphire fury x's have shipped from overclockers today, although I'm still uncertain whether I would prefer 2 x 980 ti's, is any one else in the same position? (Moved from nvidia to Amd) and what the change in experince is like?
