The Fury(X) Fiji Owners Thread
The 40in is lush tbh, although I did go through a small period of thinking it was just TOO big!! Pushed it back another 6in and now it's perfick ;) :D
:cool:
I've done exactly the same, was a little hard to get used to at first , but moved mine back & anything less than 40" looks tiny now :p
1215 is wayyyyyyy too low with unlocked voltage. You can hit 1300 on hawaii with water without too much trouble, I find it hard to believe fiji can't even accomplish 1215 which is possible on air with hawaii.
The 2 i had did it oddly enough :)
Wow 4K 60hz displayport to HDMI adapter, if that is the case, then that is exactly what the doctor ordered for the non HDMI 2.0 fury problem.
Link to them if you can or just name them so we can search.
I thought you meant 4k in general :o Got my wires crossed.
290X wasn't that great an overclocker to begin with, the manufacturing process for dies improves over time so Hawaii is very mature now. Fiji is a lot bigger and all it takes is one low quality area of the die to limit what the rest can do.
:cool:
It s a 21:9 right, so the 40" diagonal is not the same screen size as a 40"16:9.
looks to be a perfect size for me.
The chip is a lot bigger, a lot more transistors, a hgiher transistor density
hi all.
after much demand i have uploaded some scores for fire strike. i used a test ssd and didn't realise the sysinfo was unable to read my cards clocks, also will need to update the vantage version. this will be done for my next runs.
this is my best fs score so far
http://www.3dmark.com/fs/5476446 card at 1195mhz core and 595mhz hbm
Extream http://www.3dmark.com/fs/5476467 same clocks
still difficult to maintain high clocks in these
new cloud gate and vantage scores
http://www.3dmark.com/cg/2912011 H.O.F 11th place single card 49th fastest ever at 1220mhz core / 630mhz hbm
Vantage (v1.1) http://www.3dmark.com/3dmv/5309828 H.O.F 15th place single card 52nd fastest ever i think with same clocks as CG or very similar.
all runs done at 1.29/1.32 +100mv in AB once TDP limit in the bios is sorted i really believe the card can do a lot more. i can remake the video showing some everyday ocs that are possible. not sure about releasing exactly how i have achieved this yet as it can be rather buggy but i will say it was achieved using msi AB 3rd party control methods.
Someone wanted more pictures of fury x in use ?
Thats approximately what I see of it, the camera is exaggerating the illumination though
So my 2 sapphire fury x's have shipped from overclockers today, although I'm still uncertain whether I would prefer 2 x 980 ti's, is any one else in the same position? (Moved from nvidia to Amd) and what the change in experince is like?
If Crossfire works,well,when it works the scaling is much better than SLI.
I'm waiting to see how the drivers shape up before I get another one though.
Meladath ye 1300 hawaii..... to have 1250 on one i have i need +200mv and thats max without artifacts
