***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Just got my istick 40w TC. No idea if I'm doing it right.
28 gauge ni200 at 0.12 ohms. Set for 420f. Using bacon cotton.
Vapes fine but keeps hitting the temp limit and cotton is going slightly brown.
From what I read, TI works with everything, even non temperature control mods. BUT it can be dangerous if its ran too hot and start a chemical fire. (and so is ni200 if not used correctly.)
as far as I'm aware, DNA40s do not officially support TI coils but people have been using them since it's been out. It just don't read the temperature correctly as it uses a different scale and chart of ohm vs heat increase, that's available on the other chips, you just have to do the conversion yourself.
(IIRC) I read 230ish F on TI is actually around 420F, it's worth doing a dry cotton burn or googling it, there's a massive thread on a states forum discussing it.
what RTA are you getting? :)
Ah, I wasn't sure which is why I switched back out to Ni200 until I did some research - what I'd originally intended to do until my little mistake, didn't want to do my self any harm knowing there was some controversy surrounding TI. I'll do some burn testing later in the week at work when I'm supposed to be doing a stock take :D
I'm looking at a couple of RTA's, the first couple will be cheaper ones, as I'll need something for using at work that I can afford to break..
Goblin
Goblin mini (hows the air flow on this being bottom fed?)
Aromamizer
Billow V2
Zephyrus
Goliath
I'm leaning towards the Zephyrus and Aromamizer, which I'll likely follow up with a squape R for using at home, I was looking at the Hurricane but it appears to have a crackable cylinder.
Is there a 2nd hand market for stuff for vaping as it seems a lot of ppl seem to have a lot of batterys and tanks and just wondered if they sell stuff they have moved past. Is it worth buying 2nd hand. Just ppl say get a 30w battery and nautalus mini but man are they pricey. Im dirt poor so :p
How much is them new btw, just curious and would amazon be a good place to get em. Cheapest place u know that is genuine?
http://www.amazon.co.uk/Mini-Nautilus-Adjustable-Airflow-Genuine/dp/B00M0B03WW About 17 quid, better than vape stores which list it as 20+
Found a 15% off code duno if it works yet tho for Vapeinc. website (is it trustworthy u reckon and in the UK?
As the istick 30 there is 32 quid and the nautalus mini is 18 quid. Roughly take 15 % off that (hope free del) then it comes to £42 ish.
I used vapeinc to get my Sigelei 75w, first time i used them and they seem pretty good to me!
With regards to used gear, its not something i'd consider when it comes to batteries, i'd only ever buy them new, but for tanks and stuff it should be fine. You could get a mod that has replaceable batteries used though i guess!
Edit: as a rule of thumb with vape sites, ALWAYS search for discount codes for them as the majority do have 5-20% off codes!
Goblin
Aromamizer
Billow V2
Zephyrus
Goliath
The airflow is very good.. highly adjustable and it has an affect on the vape.. I've been using it all day. You will; Or at least I do get juice coming out when you fill the tank, but that's could be the way I'm filling it but after that no juice at all.
The tank on the hurricane is a joke, they have been breaking with normal use and without tank cracking juice. You will need to get the metal one pretty much straight away.
1x eLeaf iStick 30 - Blue for £31.99 each
1x Aspire Nautilus Mini BVC for £17.99 each
Discounts : £-8.50 GBP
Subtotal : £41.48 GBP
VAT : £6.91 GBP
Shipping : £0.00 GBP
Total : £41.48 GBP
Best prices i could find and a hopefully decent store, hope i found the best deal for em. Hate how expensive they are for what they are, just a battery with a few gimmicks and a thing to hold liquid made of metal and glass lol. How the heck are they expensive for what they are.
I will probably give the evods to my bro see if he can use em ok.
Btw i wana find some 50/50 juice that is uk made, preferably vanillia or something as nice as i still rather like that one i got by magnif ecig but i think id prefer a known PG VG mix number as i dunno the mix. Oh and 11% nic i think. Tried the strawberry one i got its not that noticeable and wasnt too great vs the vanilla imo from hangsen. I really want to try one of them coka cola bottle sweet thing flavors, duno which brand to pick for best and cheapest tho think they go by gummy cola or somit sometimes. Rather not spend ever more than £3 per 10ml bottle tho. £4 if its good brand tho.
Whats ur fav shops with discounts and whats ur top 3 flavors for all day vaping.
Should treat you well i think! They're both pretty cheap in the world of vaping, it's like anything, quality costs money.
Most juice companies who mix their own will let you pick the ratio of PG/VG that you buy. I mix my own for the most part now, but i used to use health-e-vape a lot, they have a hell of a lot of flavours too, Tripwire make some good ones, nova juice, and vampire vape. If i buy any premade nowadays i tend to go for US juices, from vapeclub or spiritusvapes!
Glad to hear you packed in the cigs, well done, had you tried before to quit? Was it easier with Vaping?
Buy some peaches, eat the peach, suck the stone and the rough surface of the peach stone will clean the plaque surface of your tongue which is often the source of bad smells. Brush and use floss (tape), all help.
Status
