From what I read, TI works with everything, even non temperature control mods. BUT it can be dangerous if its ran too hot and start a chemical fire. (and so is ni200 if not used correctly.)
as far as I'm aware, DNA40s do not officially support TI coils but people have been using them since it's been out. It just don't read the temperature correctly as it uses a different scale and chart of ohm vs heat increase, that's available on the other chips, you just have to do the conversion yourself.
(IIRC) I read 230ish F on TI is actually around 420F, it's worth doing a dry cotton burn or googling it, there's a massive thread on a states forum discussing it.
what RTA are you getting?![]()
Found a 15% off code duno if it works yet tho for Vapeinc. website (is it trustworthy u reckon and in the UK?
As the istick 30 there is 32 quid and the nautalus mini is 18 quid. Roughly take 15 % off that (hope free del) then it comes to £42 ish.
Did u use a code and if so what was it and for how much off?
tried this and it worked UKVT17 17% off.
Ah, I wasn't sure which is why I switched back out to Ni200 until I did some research - what I'd originally intended to do until my little mistake, didn't want to do my self any harm knowing there was some controversy surrounding TI. I'll do some burn testing later in the week at work when I'm supposed to be doing a stock take
I'm looking at a couple of RTA's, the first couple will be cheaper ones, as I'll need something for using at work that I can afford to break..
Goblin
Goblin mini (hows the air flow on this being bottom fed?)
Aromamizer
Billow V2
Zephyrus
Goliath
I'm leaning towards the Zephyrus and Aromamizer, which I'll likely follow up with a squape R for using at home, I was looking at the Hurricane but it appears to have a crackable cylinder.
Do most Vapers also smoke cigarettes?
Interesting article here http://onlinelibrary.wiley.com/doi/10.1111/add.12730/epdf
