- 5 Jun 2003
- sawley/ long eaton
There is a setup file in that folder
You're not alone. Got 2 systems here waiting for the folder to appear.... and before anyone asks, yes I have it set to display hidden folders
this is what you get when you click the setup.exe
and this is what you get when you click install now lol
my $Windows.~BT folder is 5.96GB
if u haven't got it then maybe your not in the first waveBeen checked my tablet and 2 laptops didn't have hidden $Windows.~BT folder.
The $Windows.~BT folder on this laptop is only 140MB![]()
Check your Ethernet traffic, as its probably downloading temporarily elsewhere. Had the same on one of my yokes, and checking it afterwards showed the folder structure reorganised and approx 6GB in size.
No $Windows.~BT folder for me. I guess it's to do with me being on build 10240. I'd still expect it to update tomorrow though?
Installation Started: Windows has started installing the following update: Upgrade to Windows 10 Pro
