Man of Honour
- 16 May 2005
- Manchester
http://i153.photobucket.com/albums/s208/JonnyM_2007/20150729_134039_zpsstzk5rjt.jpg
You should have that roady .
Looks like a snug fit
Looks like a snug fit![]()
Sorry, if it's fsa then it wont be branded as shimano. Shimano chainset would still run on the fsa though.
Strava says it will be available for the 810 aswell? Is that updated yet?
Run the 25mm tyres at 80-90psi instead.
how does that happen? how old are they, were do you store you bike etc? I have never seen a tyre deteriorate that bad over a normal tyres life.
Don't run your tyres at max. Not unless you really like feeling every bump in the road.
The larger the tyre the less PSI you can run it at compared to smaller tyres.
