Right, a new one on me guys, from a MTB background anyway, I've just fitted my new Conti Grand Prix 4000s and although the back one is fine the front one, at anywhere near 120psi, is rubbing against the top of my forks... I lower the pressure - right down, and it stops
The new tyres are exactly the same size as my last ones, any ideas?
That's hilarious![]()
No, completely different tyres. Budgets to premiums
Okay then, I'm about 15 stone so less pressure is okay? Thanks chaos, I'm a compete novice on my road bike!
Not if you are the owner of the Fiesta who had done nothing wrong. Their car got crunched by the front of the one he was dragging round.
...or use the widely accepted 15% drop calculation http://www.dorkypantsr.us/bike-tire-pressure-calculator.html to give yourself a starting figure to work to.
I mean, let's not pretend that it's universally accurate, the website itself lists several valid criticisms of the method. It's probably a good starting point but it's not going to work for everybody.
15% drop is definitely the pro way to go. Choose the 45/55% split options for front/back weight load however.
They work but they do flex and make loads of noise banging your tyres and from flexing (boingy clattering!). I found clearance ok with 23mm but really tight with 25mm and saw some rubbing. No matter how much adjusting I did.
