Doesn't the share need to be synced both ways with bit torrent sync...what happens when you delete the photos on your phone? Does it delete them off your server ?
Like Dropbox?
I need to be able to copy a file from PC to server...not sync directories both ways...I understand that bit torrent sync as a toggle for sync all off...but this still means when I delete of PC it will delete off server...
Not as far as i know though i freely admit i only have ever used it for the odd file here and there. AFAIK it only deletes things if you delete the original share.
IE if you set up a folder with pictures in it on your PC (the original share source) and downloaded to your phone, if you then delete from the phone they stay on the PC, if you deleted from the PC though the phone obviously loses them also as it has nothing any longer to sync with.)
This may have changed in the latest version though and it may now allow deletion from both ends. The easy way around that is do not delete stuff from any device you share it to.
