I'm so hoping this is 100hz
Acer have confirmed to me that it is, see here: http://www.tftcentral.co.uk/news_archive/34.htm#acer_x34_100hz
And a heavily 'overclocked'(?) Acer at that. How is that going to be good?So does that mean it runs in 100Hz ALL the time? I was a bit puzzled when they were talking previously about G-Sync overclocking it, but G-Sync isn't always in operation. So is it still 100Hz when you're in Windows etc.?
it's yet to be confirmed by Acer to me, but i have asked. There's rumours that only applies when using G-sync specifically, so it's possible that the normal operating frequency of the panel remains 75Hz maximum - so for non G-sync use, AMD cards etc. it might be a function of the additional G-sync module perhaps, allowing frequencies from x to 100Hz. that would seem viable, given the panel from LG.Display is a 75Hz max panel natively.
According to the initial spec sheets we had in April the G-sync model would also support ULMB (Ultra Low Motion Blur). We have yet to confirm that this has not changed, but we hope to see it included. It's feasible that even if the screen can only operate up to 75Hz outside of G-sync mode, the strobing could possibly be double to 150Hz to avoid noticeable flicker on the screen. 85Hz is commonly considered a lower limit for strobing without flicker becoming too distracting, but tricks to double the strobe frequency have been used by other manufacturers before for lower refresh rates. We will see how this pans out. Keep in mind you can't use G-sync and ULMB at the same time.
I started a thread to ask for some technical advise about this "100hz with gsync" on a panel that should be born @60 and "possibly" brought to 75 but with known problems with frame skipping. Then I read this:
and I'm even more confused. Strobing? Double the frequency? Tricks? That's what I was asking here. Maybe there's no way to answer that, maybe it's just a stupid question. Surely it sounds strange.
Didn't know anything about ULMB strobing the backlight and such. It's all very clear now, thanks....awesome explanation...
Is the power brick for this monitor on the wire, or in the monitor? The retailer I returned my B276HKs to put the buzzing down to the inbuilt power brick, so I am hoping to avoid that on my next monitor.
So do you guys think its worth waiting for the Gsync version of this monitor or jump in for LS34E790C?
I've been on the fence for months now and getting impatient.
