Right so, my bottom bracket/crank is creaking as I'm cycling, every revolution or when I'm out the saddle it's groaning at me which is becoming a bit annoying. So going to service my bike properly this weekend re greasing and taking some of it apart to try find the culprit!
This has lead to me needing some parts & better gear to get it done properly so have formulated a nice shopping list for what I need which I may need some advice on;
Work/Repair stand -
http://www.planetx.co.uk/i/q/TORISP...ycle-repair-stand---rotating-clamp#reviewstab
Torque Wrench -
http://www.wiggle.co.uk/lifeline-essential-torque-wrench-set/
Better tool kit -
http://www.planetx.co.uk/i/q/TOJW41PCTK/jobsworth-pro-41pc-swap-shop
Degreaser -
http://www.wiggle.co.uk/muc-off-water-soluble-degreaser-500ml-aerosol/
Lubricant (dry & wet) - Recommendations please?
Need some better cycling gear i.e. not a cheap jersey and cheap shorts so any recommendations for a jersey and bib-shorts (didn't take long for me to want to now have Lycra!!).
Proper Jersey -
http://www.rapha.cc/gb/en/shop/trade-team-jersey---yellow/product/TTJ03O
Bib-shorts - Castelli maybe? I'm not sure, but don't want to break the bank with Rapha (£120+!).
Cycling Shoes -
http://www.wiggle.co.uk/shimano-m089-spd-mountain-bike-shoes/
SPD Pedals -
http://www.wiggle.co.uk/shimano-pd-m530-mtb-spd-trail-pedals/
Cleats -
http://www.wiggle.co.uk/shimano-spd-mtb-cleats/
Any assistance or opinions on the above would be great!
Got around £300+ to spend across the items.
Stand is a good choice and price, Torque is a good buy, Tool kit seems good (there are cheaper but then you'd end up buying allen keys & pedal spanner). Degreaser, there are other options but for starting out not much price difference (just get whatever is on offer!).
Lifeline Green for lube (as you commute in all weathers?), although the packaging seems to have changed and it's not green any longer?! The
Park tool Chain cleaner is a good investment (better than the juice lubes one).
Shoes and Pedals ok, the pedals will come with cleats so you don't need another set (although you will in future, you should get more than 6 months out of a set).
Bib shorts are a very personal preference. Especially on a budget! As I'm fairly stocky I've found fitting my big thighs and short torso/legs an issue. I've gone from cheapy
DHB Active bibs and
DHB Flashlight (bib version, not in stock) for commuting. More leisure riding I've gone through
Northwave Logo's and more recently (last 2 days) finally found
Castelli Evoluzione (after trying various others before).
Jerseys I've never really matched to shorts, I have DHB Active,
Primal Tagged,
DHB Flashlight (good for commuting),
Northwave Logo (about my only matching) and various others.
I guess budget really does decide for me as I don't usually buy 1 of anything (2's and 3's)... So I don't like to spend more than £40 on commuting bibs, £60 on leisure bibs and £30/45 on jerseys etc etc.
If you do any work with spokes the basic spoke keys in those PX kits are rubbish and will round your nipples (oooh matron). I'd recommend one of these:
http://www.wiggle.co.uk/lifeline-performance-spoke-wrench/
