Sweetfx is amazing for this!!!!!!! A good few people use it on here.
Does it affect the fps at all ? Ive found a real nice sweet spot with the graphics options and dont want to upset it too much.
(scrolllock toggles it on and off)So it begins.....
I have found no performance hit whatsoever. I have tested with it on and off under the same circumstances and it was the exact same.
Here is the one I am using:
https://sfx.thelazy.net/games/preset/3450/
Download the files under the title recommended Step 1 and extract to your game directory.
then download the bit that says Download Preset and follow the instructions to add the text from that .txt file into the config file.
Start game, press scroll lock, be amazed(scrolllock toggles it on and off)
Good luck!!!![]()
Good luck!!!![]()
Gamble likes to play with his eyeballs covered in Vaseline.I heard it smooths out the fps.It losses a LOT of sharpness from the game just putting a a dull smoothing affect. It's like looking at the game through some instagram filter.
Some of the comparisons, the game looks better with it off. It losses a LOT of sharpness from the game just putting a a dull smoothing affect. It's like looking at the game through some instagram filter.
Inject smaa instead of fxaa in the sweetfx config. Makes it even nicer.
No problem mate, I was only messing.
Hopefully 4 of us going for the 10 million achievement today...
....Lethal, where are you?
Im assuming you mean this section?
#define USE_SMAA 0 //[0 or 1] SMAA Anti-aliasing : Smoothens jagged lines using the SMAA technique.
#define USE_FXAA 1 //[0 or 1] FXAA Anti-aliasing : Smoothens jagged lines using the FXAA technique.
I don't think I could handle the pressure of not dying once! Did you manage it or are you still going?
Yes mate
