I was expecting around 2-3k from my shoes but they sure as hell exceeded my expectations! what pair should I get next, dhb ones are super uncomfortableI've got a brand new pair sitting there for the past 4 months.. pfth! sho...
Weird question, what do people do with worn out bibs/shorts/jerseys ? In the bin/recycle/charity bin ?
Thanks mate! It's funny, but playing with the limit screws is usually one of the first things that comes up in all the guides... so what am I looking at first then, a quick turn on the cable adjuster on the rear mech?
Am I really seeing 2-3k miles per pair of shoes? I've had my original Shimanos for 2.5 years and probably over 12000 miles, no signs of wear whatsoever?
I have some fairly cheap Bontrager's now, which are really comfortable, comfier than slippers!
Decided on my new wheels but need new handlebars as well (Was knocked off my bike last week) but have no idea what's decent and if I should go standard size or compact?
Currently ride a Giant Defy 3, can't say I had any issues with the bars, looking to spend upto 25-30 if anyone has any recommendations?
I wouldn't bother with ceramics for the price. My bosses didn't last very long on the k force chainset.
Various people say different things and I've even been told to clean them out and run them dry.
For your giant I'd just get a shimano pf bb or something like a hope.
Right thread this time, treated myself to some new bars, Cinelli Ram XL. Yummy![]()
I tried on some Shimano shoes in Halfords that fit beaut! Opted for some Giro Trebles instead nd regretted it slightly as they're very tight, I pop them on, pull the straps across but I wear them loose to stop pains. It's bursting on the outside of my left foot where my toe starts which is where I got my pain on long rides before adjusting my cleats.
<snip>
Every month or so I get it up on the stand and index then properly too as eventually they become a pain.
I clean my cassette and chain monthly too so they get readjusted when I do that.
I've been firmly steered away from ceramics now
If I'm looking at buying the tools to change my own BB bearings, any recommendations? Last time I looked the Parktool bearing removal tool was £40 and the BB installation tool was £56 (although this version is £26).
The bearings themselves, should I be looking elsewhere rather than wiggle? Options seem limited: FSA BB86 £26 or a £15 hope one I'm not 100% sure fits.
@grudas
I can't comment on their longevity but my Sidi Dragons are incredibly comfortable. My friend has one of the cheaper SPD Sidis and he says they're good too. I've found them to be less narrow around the toes so I get far less rub on them compared to my older Shimano shoes (not sure of model).
yeah I've been looking at sidis too! found my shimanos really comfy tbh! it's funny seeing my sock over the hole nowshould I just ride them till the sole falls off?
nearly 2mph off!!!
https://www.strava.com/activities/368646117/overview
https://connect.garmin.com/modern/activity/865017539
wouldn't it be cheaper to just, buy a quality BB?![]()
Remind me what chainset and BB you've got again? I think that Hope bearing is a replacement bearing for Hope's bottom brackets rather than a replacement bearing for BB86/92 so not much use to you.
I've read that for pressfit bottom brackets you're better off with something with plastic cups as these will conform to your bottom bracket shell better than a metal one. Manufacturing tolerances aren't great so the plastic gives the shell some error room. Makes sense, even though you'd think metal was the obvious choice.
I can't see the Garmin Connect link as we're not Garmin BFFs
I can't believe how knackered my legs have been all week after the weekend's cycling. I've not ridden much and I've really been struggling to put out any power.
Shimano shoes are a good fit on me too, my pair of XC30's are doing well (3000+ miles) and are comfortable, more recently the flex in the uppers has started to cause me some foot pain (along with cleat adjustments) after long rides. I really need stiffer shoes next year and will be moving to SPD-SL. Probably Sidi, as they're damn good looking shoes!
Cassette similar to me although I wipe down and relube my chain weekly!
Is it? How much harder is it to change the whole BB and any different tools needed? Don't see the BB86 mentioned as coming with bearings though...?
Tape over the hole? Gaffer! Or maybe glue some old tyre inner tube over/under it? Black socks?
Then again that takes effort, have you fixed that puncture yet slacker?!![]()
Hi guys, got a new job (yay), 2 weeks holiday before I start, maybe 1 week from 7th > 12th and potentially might be able to do something like Mallorca with some bike riding.
Would be going with my dad (he is kindly paying, but not cycling) so needs to be all inclusive a nice hotel in a good location near some bike rental shops (but am looking into taking my own bike).
I know its been mentioned a lot on here but can people recommend some nice places to stay so I can check them out on tripadvisor/sites for availability and price. Any help / advice greatly appreciated.
p.s. Manchester commuters.....was like cycling through a swimming pool on my way into to work today!!! mental
