- 9 Nov 2014
I'm using an AP-15 at the moment. Does the job nicely.
Whoever has a TX and doesn't have a Hybrid cooler is mad in the head!!
Playing around with the voltage I notice it doesn't really help when the card is in demanding scenarios.
Running the shadows of mordor bench I got a solid 1.46 ghz with +260 on the core, 270 would crash. I upped the volts by +80 and suddenly the card was boosting up to 1.5 ghz but then also back down as the power level was hit. In the end it didn't add anything to my score.
Maxwell doesn't really scale well with voltage at all
looks good born to kill.
Have you tried a new bios yet s2kip ?
I take it you split the hose down the middle to get it like that,if so it looks great![]()
Yesterday I had a Witcher 3 session and saw the card throttle back which was interesting. Temp maximum was 51 so must have been due to hitting the 110% power limit.
Yeah it's nothing probably only 1 fps difference if that, it annoyed me though, I like solid O/C's, hence flashing the bios.
, flash it with the safe air bios, should be fine under a Hybrid as it's intended for the stock fan setup, you don't have to overclock it anymore if you don't want.
