https://www.strava.com/activities/369747984
As for the triathlon - you know I gave it a try (70.3) and failed!
That's rubbish! Those things aren't cheap and they didn't let you do the bike or run.![]()
Hey guys, only recently got into road cycling so am fairly new to all this.
Went and did 3 laps around Richmond Park today. On my final lap I felt that my lower back started to ache and now my quads are rather sore. Does this sound like I need to correct my seating position or is this just fatigued muscles?
If you're worried it's probably worth insuring it too...
Nah, I'm not that worried to be honest but my current lock is mere 2.5mm thick cable! I could cut that with the multi tool I carry...
It is covered on the household insurance should the worst happen anyway.
Not necessarily, your BB might just be knackered unless it's made noises since day one? If it has then there are somethings you can try to prevent squeaking, like Loctite.
From the factory my BB lasted 6k.
The replacement (steel bearings from a bearing shop) I had pressed in and the proper loctite (641 from memory) used by the LBS who are a Cervelo dealer.
Done 12k since and no problems, however when the first one failed it went from being good to ruined inside 2km so it was a sudden failure.
I know its not really nothing to do with my, but my friend has tried the "Everest Challenge" where he attempted to cycle it in one day, one sitting! He managed 23685ft in one day, 13 hours and 117 miles.. He failed but he said he is going to try again. Its the most climbing I have ever seen on Strava.. Anyone else got similar? Its just insane really!!
ah crap
did anyone reply to my post about me giving away my Brocken zip topeak saddle bag? did anyone want it?
I have no idea how people can do a ride like this every day for a year! Top day out though https://www.strava.com/activities/369747984
