Aye I did that after your first reply, had a brainwave
Thank you very much!
Okay, I need some wheels! Tyres are gaining flats across the tyre so they might need replacing soon. About 1k miles on them now, May have another 500 in them, lasted longer than my Giants did to be honest.
I were thinking Aksiums at £170 but they've dropped to £117 now, may go for them unless anyone knows a better deal? Budget still £170 plus then I'll need some 4000s ii's.
I can get Aksiums and two GP4000s ii's for £178 delivered.
Yes I think that may be an error! Probably more like 180.
Even with not having done any exercise previously, since May, even I can do 30miles in under 2hours.
Just make sure you don't make it feel a chore and enjoy it.![]()
had zero issues with GP4 seasons for nearly 3k miles on my CAAD8 - might go back to them for now.
Campag Khamsins from Merlin at £90ish.
at this rate everyone on this thread will have some
I've started adding a few of you guys on Strava, hope you don't mind. If you see a guy called Alan then thats me![]()
Got a week off next week, contemplating heading up to perhaps the Surrey Hills, I've done a few small rides around there before (40 or so miles) Just wondering if a) anybody has recommendations b) fancy a ride, or even just a cake stop if you're about.
Oooooh!
What tubs is everyone running?
My clicky finger is ready to hit buy on the Conti Competition's (25mm). But please let me know if anyone has better experience with other tyres or what your thoughts are
Ribble Conti Comp 25mm (nobody has them in stock!) - http://www.ribblecycles.co.uk/sp/ro...s-continental-competition-tubular/conttuba325
@xdcx
What are you using the wheels for? That will influence tub choice.![]()
Vittoria Evo CX III 23mm glued with Vittoria Mastik One.
Same.
I just stuck my wheels into the shop and asked them to glue on whatever tyres they thought were best.
They lose air very quickly (I think it may be because of the latex tubes in them?). Not a problem for race wheels because you'll check the pressures before each race but the next day they'll have gone soft and in 2 days completely flat.
That's atrocious. Definitely see if you can get that replaced. Not up to standard that, I've luckily had no problems with any of my Conties.
Quick question about tube and tyre sizes.
I got my first puncture on the road bike a couple of days ago, my spare tubes don't seem to fit the tyres though. I have 23mm tyres, and the tubes are Continental Race 28 (700x20-25), but I just can't get the tyre to fold in over them. Did I buy the wrong tubes?
The tubes that came with the bike were 700x18-23, but I only seem to be able to buy them from Planet X
