So does anyone own a velocity rda? Tempted to give dripping another go.
Or anything else people would recommend?
I have two of those and I love them for the simple reason that they are the easiest RDAs to build on. The flavour is good and I like that I can screw the airflow down over the holes when I pop it in my pocket, thus stopping juice from potentially running out.
It's a great RDA.
Can someone look over this shopping list and see if it's okay or do you recommend anything else other than the Kanger subbox?
- Authentic Kanger SUBOX Mini Black Starter Kit
- Authentic XTAR VC2 2 Slots Li-ion USB Battery Charger w/ LCD Display
- Authentic Samsung 2A USB AC Wall Charger Travel Adapter (UK Plug)
- Authentic Muji Rectangle Cotton Wick for RDA RTA RBA Rebuildable Atomizers (10-Pack)
- Authentic Samsung INR18650-25R 3.6V 2500mAh Rechargeable Li-ion Batteries (4-Pack)
- Authentic SMOK TFV4 Sub Ohm Tank Clearomizer Kit
- Total $125.83
All from FT, looking to place an order today so quick replies would be great![]()
Look OK but buy your batteries locally from someone like Torchy. Fasttech takes ages if there are batteries involved.
The Muji cotton you can buy a mahoosive amount direct from Muji for next to nothing so I'd forget FT for that too.
