Seeing as you've just purchased it you already have proof of the value?
So what about the Speedy Pro 3576.50 ? http://www.iconicwatches.co.uk/omega-speedmaster-professional-moonwatch-3576-50-00.html
Trying to narrow down the choice here, and as much as I like the 'classic', quite frankly paying 2.5k for a watch with a plastic top isn't fantastic... that 3576.50 also has the moonphase complication but stays symmetrical, and has a display case back for movement p0rn
Opinions? I won't buy /immediately/ anyway, need to buffer a bit the last couple of watches :>
If you're fine with it not being a moony at all (it really isn't when you're changing the movement and adding complications - they're just giving it that name to sell things), then go for it.
I don't know who makes the movement for that, so it's probably an ETA-based one? Again, if you're fine with it not being an Omega movement then go for it.
Any suggestions that aren't too chunky or have mad hands? Most of the dive watches aren't terribly elegant!
It's based on the original movement plus a module for the moonphase.
Iconic have the display caseback moonwatch for £2870, so are you bothered about the moonphase enough to spend another £140? I think the display caseback adds a bit of extra thickness?
4 subdials is a bit much really.
Well, I'm definitely not an astronaut, so having an EVA ready watch isn't too essential (altho I do like the connection) however I *am* an amateur astronomer, so the moonphase complication rings a bit of a bell...
Is the display caseback too thick? I wonder, I'll try to google pictures; thats an interesting point.
You are not going to easily get a watch for that kind of use that isn't a dive watch - And dive watches adhere to a certain style, which you say he doesn't like. So options are severely limited really.
The only one I can think of is a Nomos. 200m water resistance, elegant, suits both male and female wrists, sapphire crystal in a stainless steel case. They exceed the budget by around £500 though, but would be my choice.
Quartz seamasters are quite slim, they're well made and will last forever. I think that's the first and last time I'll ever recommend one but I think it fits the bill.
The style of some of those looks right but he's set on an automatic - which I do understand, there's something about a mechanical watch that's somehow more appealing and romantic
The auto is just a bit thicker but still fairly sleek for a diver, which is why it appeals so much to me.
