thanks it's expensive though £9 for 15ml![]()
I see Cloupor have another mini mod, this time its 1mm taller and 1mm wider than the mini, its a 50w device and features TC as well....
DIY crew
Here's a recipe for Stanley Clark's Snake Oil which I'm sure most of you have all tried.
Ordered the concentrates last night so hopefully they'll be here tomorrow. Will report back with results.
LINK
Hence why I self mix, I don't do it the cheapest way but I still got 400ml for a shade under £25.
DIY crew
LINK
I want to try this but I have no idea where to buy the flavours from? care to share please? Saves me hunting around![]()
Well, i've finally joined the club, got myself a nautilis and a eleaf, basic compared to your setups but fingers crossed it'll be good enough to keep me off the cigs.
Seems to be making a wile bubbling though, i started it on 5w, moved up to 20w now but still bubbling, any ideas? I have a suspicion my current inability to remember to hold it vertically may have caused the issue
Chefs Vapour will have all of those
FA stands for Flavour Art, TPA/TFA is The perfumers/flavour apprentice (same company). They also sell bottles, syringes, PG, VG and nicotine base.
I'd also advise grabbing a set of these and mixing my weight rather than volume
http://www.ebay.co.uk/itm/111617306926?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Top man and scales order too! Ill stop stealing the gf's syringes now![]()
20w on an nautilus is a bit high? careful you dont burn out the coil, you do not want to get a burnt hit... nasty...
You will still need syringes for PG,VG and Nic though, but it saves using 10+ syringes on a mix like that or contaminating your concentrates
depends on the coils you have, 1.8 or 1.6ohm, id stay under 15w.
I use these and decant my PG/VG into them.
My Nic base I put in a 30ml squeezy bottle too and refill when needed.
