Couldn't hit **** tonight!!! Awful!
I know, you killed me twice with shotguns. Had to leave the game though as I realised for some reason I had a 200+ ping.
Was your screen turned on?
My bad bud, not played much Domination so pay and spray was the only way.
Tess - Corsair M45/65. The 45 has a great sensor and is big enough for man hands. 65 if you want a sniper button and rgb thingy.
*Ordered the 24" AOC G sync Monitor![]()
how dare you
Some good rounds last night... going to have a break tonight but will be on tomorrow![]()
don't know much about that screen josh, hope it's got really deep blacks
Not heard of any changes in the last patch, are you running a different setup than normal?
Also WTH was happening with you mic last night?
Only lost one round on TN, but we got a bit of a spanking TBH. Xonatic, you need to cap more flags when you're next to them in the tank. The longer you wait, the more rocket spam will spawn!![]()
From the research I've done it looks decent, gets good reviews for colour pereception and vibrancy. Not sure on the deep blacks but it's a TN panel so won't be great.
It has the same panel as the BenQ 24" 1080p G sync but is around £80 cheaper, so was a no brainer for me. Hopefully it proves to be a good purchase.
Wife is away and you "might" be on tomorrow. Poor show old bean, poor show!
On zavod i knew we die soon as wew tryed capture c or d. I was shooting a bunch of guys on hills. killed a couple trying to C4 us and was aware of guys on roof. Them capture points should be taken by inf while tank assists to pin them down
Same AWS in the loadout as before with no changes.
I have used the L86A2 for awhile but gone back due to the limited rounds per clip.
The AWS now is like a beast and empties its 100round mag in a blink of an eye, carving noobs up.
the mic is fine, just fancy sound effects.
