So the replacement ones you had are 100% the newer revision that I put pics of a page or so back?
Yes newer version as you showed in pics, in fact the 4 hubs I have are all the newer version just do nothing.
I've contacted Phanteks to see if there is any other option, in the meantime i'm using a ModMyToys one which works but is a bit bigger, think I'll probably end up using a normal fan controller stuck in the HD space in the bottom, the Lamptron one from my old build works fine.
