£96? That's expensive
£56 for my 600,
Yeah it is, for a piece of plastic lol.
£56 for my 600,
If you don't mind IC3would like a few photos from all angles please?
was it fitted when you bought the bike or did you fit it yourself?
I think lidl sell thermal gear from time to time,compression stuff
Will do, I'll probably do them on monday though as I work tomorrow and by the time I get home it'll be dark.
It was already fitted, I don't want to spend any more money on this little 125. The next 1st big bike will get all the love from my wallet, this KTM has already reached its limit.![]()
Hopefully you'll be staying up right from now on!Both front brake calipers rebuilt - Pistons all cleaned up and I've nearly finished bleeding them, lever has gone from 1.5" of travel with no braking and then all the braking in a 20mm range, to about 1.5" of movement total, and gradual pressure right from the first movement.
Should help having 8x pistons now moving rather than just 2 or 3!!
I'm planning on rebuilding the front caliper on my ybr as practise then if I don't completely mess it up doing my front and rear ones on the SV.
You have 8 pistons of braking power on that 400? MAD power!! I only have 4 on my 600![]()
I've already got the money saved for my first bike when I pass my DAS, triumph Daytona 675R
Nice!
One of the good ones with the under seat exhaust or one of the crap ones?![]()
they all look good the Daytona's,
have you gotten some insurance quotes first for one?
BTW That's ME when I look at the bikes I can get insurance for and how much it is...
Edit:
I found some time to do the pictures, the bike is dirty as that's my daily!Just kidding... I like her dirty
https://imgur.com/a/pOY2x
how much tpft?
that's eyewatering for fully comp
No clue, bought it with all the extras, apart from my sexy +20bhp handlebar phone holder.Nice one brother!![]()
Where's the cover from for the spring under the seat?
Cheapest I found was £918 tpft, that's with £1000 compulsory excess too, garaged![]()
