Should I be running this game using Mantle or DX11 these days or is it a case of try both and see what works better for you?
Yeah I was getting a lot of that last night too. I'd have to quit the server and then rejoin to get in.
.Mine just kept black screening, but if I left it, and tabbed it it appeared to actually work.
Quick question actually. I found when using Recon the range finder did not always seem to work, unless I die. Then sometimes it comes back, what give?
The sensor is there, but just grey, in stead of having blue and red numbers on it.
Just switch weapons and it will work.
I've noticed I get double scopes quite often, sniper scopes and vehicle scopes sometimes have a 2nd scope overlayed on them. Usually lasts a few minutes after joining a server. Funny though because it gives you a range finder on scopes that shouldn't have one.
When I get the message, it generally doesn't even start the actual game (No game icon appears on my task bar). In this case I just kill battlelog and restart it from origin after which it seems to behave itself for a few rounds.
Yeah I get double sets of reticules on vehicles when using FLIR a lot. I can often fix it by seat switching or exiting and getting back into the vehicle.
Just switch to pistol and back and the range finder will work.
Ah that explains that then! Just a strange thing to keep happening really, I also find that the cross hairs randomly vanish sometimes on Conquest. Does that also happen to you guys, tend to be mainly on the Assault class though.
Ahh, well seen i havent been keeping upto date.Yeh summer patch dropped.
The messed up scopes started when they introduced the customising of scope colours I think. Don't remember getting the problem before that.
Grrr i got so annoyed when some idiot decides to steal vehicle and camp in it all game so i couldnt battle vs you guys in lav and mbt. So i just C4 his camping stealing ass![]()
