- 23 Sep 2011
- Winchester
Here is one of the original .MOV files.
https://dl.dropboxusercontent.com/u/337010/OcUK/AMBA0020.MOV
Make sure the window is clean, Make sure you've removed the protective cover off of the lens
and also, I'd make the resolution the one that isn't 21,9. Also, if you change the flicker setting to 50hz? You wont see them flicker anymore.
Never mind from a motorist point of view.
