If your Uncore Ratio is still set to auto, set it to x14 otherwise x12. Your uncore frequency appears to be hitting nearly 4000Mhz with your RAM being nearly 4 times slower.
Is it supposed to locked down on certain boards?What boards are you guys using? Are these Xeons widely supported by X58 boards?
Want to replace my old W/S which has a pair of E5430's (Core 2 era quad cores @ 2.66)
e; WHAT?! What the hell has happened to X58 motherboard prices?!
Wish I'd kept my Rampage II now![]()
Yeah, its more a voltage adjustment than a setting. Its hard to determine the exact voltage, unless I'm misreading it. Above 190, it bluescreens before getting into windows. I'm thinking of adding more volts but want to understand it a bit better before I risk frying anything (even though I have a spare chip!).
Edit - So after some messing around I figured out the voltage control. Set it to 1.35v and still no luck at 200bclk, it bluescreens before getting into Windows. I think this shows the boards weak limitations in overclocking, but I'm certainly more satisfied with 3.8GHz than the stock 2.6 I was getting last week!
If anyone has any other tips however, then feel free to share.![]()
Got the same board with 3x8GB of Kingston HyperX Fury now. Been running fine despite the OCing.Yes, I've got one ex58-ud5 rig running 3x8GB and another running 6x4GB. Both running happy, although only mild overclocks as my cases are rather toasty.
how do you manage UNCORE 3800MHz? most x56xx have stability issues above 3GHz, btw for the best stability set the UNCORE muliplaier to 12(double the speed of your ram)Success!
Changed the ram timings manually to what was on the box (8-8-8-24) and I've managed a 3.8GHz overclock with 190BCLK and 1.2v vcore.
Load temps are mid 50's, so I think there's room for more. However setting the BCLK to 200 results in a blue screen before I even get into Windows. Is this a case for more voltage or memory adjustments?
My current settings in cpuz:
set your UNCORE muliplaier to 12 and see if you can go BCLK 200+
edit: in cpu-z NB Frequency is the UNCORE Frequency for x58
Lower the ram multiplier to see what AUTO uncore multiplier you will get, and also see if you can pass the BCLK 200+That probably is the root of my issues, however I'm unable to change the uncore ratio as its greyed out on AUTO.
Running it 3.8GHz still. It fails to pass Intel Burn Test but I've managed to play Crysis 3 on full for over an hour with no issues. I'm calling it stable for gaming until I find something that really stresses it too much.
what QPI Voltage you have?
On the upside, those boards go for ~£100!
Do these usually clock to 4ghz on air?
I have a i7 950 @ 4ghz on air at the minute but im looking to replace my old 6870 to play some games and have been looking at future proofing a bit and getting a 780 ti. Would it beworth replacing the i7? Any benefits going for the x5660, easier to clock?
I'd say given the right board/cooling these should easily do 4GHz. I'm unfortunate that I have a garbage motherboard.
Going for the xeon is a good choice, its a nice upgrade to a hyperthreaded hex core for just over £50. It won't 'future proof' you however, but it'll definitely breath new life into your system.
