funny how they test them when they are new and then people go blank the erg valve, because it just gets clogged up and put a straight pipe on. i wonder how much NO my car puts out.![]()
I'll tell you when I stop coughing.
[TW]Fox;28596707 said:What difference does it make, NOX figures have no bearing on UK purchases currently.
Apart from those buyers with any kind of conscience who werent aware quite how bad the NOx is on diesels. They will probably buy petrol, and will probably buy non VW. This revelation has increased the awareness of the issues considerably.
It would be obvious to most buyers that VW are a hugely successful company. If they were to go into administration then another company would simply buy them. It's not like they are Rover and can't compete.
VW is the parent company of Porsche.I expect Porsche would be first in line to put an offer in! .
I'm ahead of the trend, my petrol VW (165 CO2) should be with me in 5 weeksFingers crossed for a massive tax resulting in an influx of people switching back to petrol!![]()
Wonder what?
If they were applying measures to reduce an emission that is primarily a diesel problem on a petrol engine?
I doubt it.
telegraph said:Motoring experts said the company would either have to limit turbo-boosters, which could affect performance, or fit a larger urea tank to clean fumes before they reach the exhaust.
I thought it was more complicated than that, with VW owning the Porsche car manufacturing (Porsche AG), but with the Porsche Holding Company (Porsche SE) owning a substantial share in VW?
I do think that it's possible they could have similar software controls in place across all their engines including petrol for various purposes. For example maybe they have software to detect when the car may be on a test drive which then increases performance at the cost of much higher emissions. Once a workaround is in place for one function then there would be a real temptation to find similar uses for it.
I would also be surprised if other manufacturers don't do something similar even if it's not to the same extent.
Barring BMW in my experience, no other car gets near their mpg figures so i would not be surprised.
You would if you drove the same cycle....
I doubt it...
Of course the problem with NEDC is that is for all vehicles including trucks, hence slow acceleration rates that no one does in a car in the real world. Thats different to actually having the car engine operate differently if the bonnet up, or, i dunno..... maybe a period of no steering angle change detected....
