- 16 Jan 2003
- Nottingham
Ad blocking involves lots of comparing of strings, 64 bit devices can compare twice as many per cycle, hence th restriction.
Pre IOS9 I could go into camera roll, press on a photo and have the option to copy it, now I have to open the photo, then select it again to reveal the copy option, then paste it. Am I missing something or have Apple added a tap or 2 to my photo copy/paste procedure?![]()
Sounds like BS to be honest.
Is anyone else suffering from numbers not being identified as contacts? I've found it seems to happen when I have the number saved as "07..." rather than "+44 7...". The lockscreen shows the number as the "+44 7...." version when I get a message, for example.
How do you jump into a day on calendar month view on ios 9? I have been trying on my friends and it wont, even with double tap. I restored to ios8 and when i tap on a day it open the day view to see what i have in the calendar.
They changed something from ios 7 > 8 too (the day preview at the bottom of the scennn) which really annoyed me, now another change to remove day view?!
I might buy a 4S with ios6. Or is it possible to load a jailbroken version of ios6 somehow? Would love to go back to ios6. Why dont apple sign all versions and let people choose the os they want instead of forcing new software which makes older devices slower and removes good stable features down peoples throats?
Yep, I had it. It was only for text messages, only on my iPhone and happened irrespective of if I had the contact saved with the number as 07... or +447...
iMessages were fine and text messages when forwarded to my iPad were also fine.
From googling it seems to be a problem that's been around for some time but I couldn't find a way of solving it. I tried all sorts of things but in the end I turned my iPhone off, sent a text from my work mobile then powered on my iPhone again. Since then it has been OK. Quite why that seems to have sorted it though I have no idea.
On a different note, is anyone else having problems with intermittent What's App notifications? Quite often my iPhone doesn't vibrate or make a sound when a message comes in. The screen lights up and it shows a notification on the lock screen but there's often no sound.
