The first one, you paint it on so there's no chance of over spray either.
I agree Craig the Wurth stuff really is crap, used on my YBR after I replaced the chain and in a couple of weeks you could see rust developing already.
WD40 Chain lube![]()
Ok, redeemed
Is that the one that makes your chain white, or the other one? My only problem with that stuff is the mess! I had a sample bottle which I used on a courtesy bike. Worked and stuck nicely, but lots of jizz and stuff everywhere!
Ahh that's the chain wax, not the normal lube.Yeah it's the white one, looks so out of place though riding with a white chain!
Got the new engine in to find that one of the mount holes has been ****** with. Can't get a bolt more than 5mm in....
Bad mount:
Good mount on old engine:![]()
Spoke to the guy I bought it off and he has agreed to pay to get it drilled.
That looks like it's been drilled out. Probably had the bolt snap off and had to drill it.
Well, just ordered a Xiaomi Yi and waterproof case.
Now to find a decent 64gb SD card and genuine gopro curved mount, j buckle and little extension thingy.
Had 2 cars pull out while filtering past slow moving traffic this morning with 500m of my house! neither bothered indicating, just pulled right out of the queue of traffic. I sensed both were going to do it so allowed room, but should be able to capture some nice driving on my commute!
How much all in Paul? Tempted but new tyres and all weather biker treatment this month.
For camera, case, official gopro front helmet mount and 64gb samsung EVO card.
I'll have to get me one of those cams and go dogging
