Thermal bottoms on today under my jeans, much more comfortable ride to work, legs didn't feel like they were going to fall off![]()
though was a little warmer anyway here.2C again here this morning. My biking season is well and truly over![]()
You can probably get over 4 hours on 32gb sd card.![]()
had a woman today as I was just about to exit a roundabout,she pulled out right across my path didn't even notice me must have been in a dream,just didn't care a toss
one of those moments when your sixth sense kicks in and expects it to happen just before it does
Just change the sprocket as they are cheap,might snap a tooth or two off if you flip it,not worth it regarding a vital part IMO,chain could come off and lock the wheel ect or smash all your engine casings up
Some front sprockets arnt smooth both sides either,some have a raised bump around one side so if you flip it it will misalign the front and rear sprockets
I wouldn't cheap out on £17, but if it was a viable option one to consider for a temp fix. Changing the front half way through the estimated chain life really is helping with keeping my chains alive longer.
