Caporegime
- 30 Jul 2013
Beta is open to everyone Gregster!
Meh, no Beta for me (I forgot) Anyone have a spare key for me?
Windows 10 Fixed Issues
[355.60] Frame rate drops to around 20 FPS in MechWarrior Online after driver
update. [1679323]
[353.62] Games made with RPG Maker exhibit flickering on Windows 10. [1674830]
Windows 8.1/Windows 8/Windows 7/Windows Vista Fixed
Issues
[Mosaic] DX Swap Group/Barrier causes flashing on slave displays. [1689421]
Anyone know if battlefront beta will be dx12?
Battlefront Beta and the full release are DX 11.1 only.
BF5 next year will be DX12
Battlefield 5 Can't wait.
Diamonds ta.![]()
... brainfart on my endHmm I dont have the beta in my lib.![]()
If you go in the console and type list on SW Battlefront it says Render: DX12Enable
Valkia found it first but I can confirm I checked on the beta and it also says the same on mine.
Curious!
http://forums.overclockers.co.uk/showpost.php?p=28657247&postcount=1298
Interestingly if you type it in render.DX12enable it then says
Win32 status : Failure
yet I am on Win10.
Already speculation it could be enabled in a future patch.
Have you tried render.dx12enable 1
